I know the difference between under, over, heavy and smooth sickle sections..... However my sickle seems to have some of all..... I have a Ford 501 - it looks like the bar has been added to since it is a 9' one - don't know if that would be a factory job or not..... the stock sections appear mostly to be underserrated - it appears that about half the guards have serrated ledger plates and half of them are smooth..... ANYWAY, i cut mainly ditch grass for now - someday hope to do some alfalfa or something, but now it is just grass or weed spots.... which type should I be using? does it depend on what I want to cut? most high capacity and new machines seem to use overserrated and I put a couple of those on - but I am ready to replace quite a few now that my hay season is over ..... ..... .isn't that always the way it goes..... it cuts good now - but only if i go quite slow - so mowing is slow going to say the least.... if the grass is perfectly straight and no short or fine ones or not tangled and down is does go a little better - but definitely time for some new sections..... is there an easier way to get a good looking rivet job other than just pounding them down?
