Trick for polishing billhooks?
Tom A
06-16-2003 04:09:21
Bought an old NH 66 baler that had been out in the weather unused for a few years. Got it working pretty well, but have a problem with knots hanging on to the billhooks sometimes...more often than I'd like.
They were hanging up almost all the time and I used some fine sandpaper on the billhooks and cleaned them up and they're better now. Had a really hard time getting my hands in there to do a good job, though, and would like to do it better.
So, short of taking the knotters apart, is there some good way to polish the billhooks so the twine slips off easier?
thanks!
Tom
tom randall
06-21-2003 04:10:40
 Re: Trick for polishing billhooks? in reply to Tom A, 06-16-2003 04:09:21
yes, listen to kelly he is on the money.the knife arm must actually rub on the billhook . I rebuilt the knotters on my 69 and replaced the billhooks,knife arms mainly because of the condition of the brass bearings. Was suprised that the price of these parts at my nh dealer were not bad. ps. check out the new baler at your nh dealer, 40 years newer with the same exact knotters except gear driven. tom
larry
06-16-2003 12:53:57
bought a 273 that had sat in a cattle shed for a couple of years carried a can of wd40 and soaked it down good every load for a time if you din't it would break the twine.A year latter well i guess i better not say anything hay down and you know what happens when you start braggin
Kelly C
06-16-2003 18:12:53
 Re: Re: Trick for polishing billhooks? in reply to larry, 06-16-2003 12:53:57
Speaking of " you know what happens"
Not only did I get my H stuck wile mowing.
After I got pulled out and after raking my hay.
The draw bar suport that bolts to the under side of the tractor broke off as I was reattaching the draw bar!!!!
Go figure :-/
It suppose to rain tonight and cant use the baler.
Roy in UK
06-16-2003 09:37:41
A little tip....
Before you put your baler away at the end of the season, rub a little grease on the billhooks to stop them rusting again
Kelly C
06-16-2003 06:00:33
third party image
I have a NH 68 but I think yours may be simular.
There is one bolt that hold the knotter down.
Take this bolt out and you can raise the whole knotter up.
This gives you easy access to the bill hook.
You will also notice that the knife arm moves as you move the knotter frame. ( watch fingers)
The knife arm is what pushes the knott off the bill hook. Move it up and down a few times and observe the gap between the knife arm and the bill hook. I am not sure how big the gap should be ( my manual is out in the shop) but if its to large you can bend the knife arm to close the gap.
I have not had to do that yet. So cant help on how to adjust the knife arm.
J Kirsch NY
06-16-2003 07:52:05
 Re: Re: Trick for polishing billhooks? in reply to Kelly C, 06-16-2003 06:00:33
You might want to check the brass rollers that are located on the other end of the knife arms. If they have any flat spots on them, it can cause the knot to hang up on the billhook. They can be changed without having to remove the knife arm itself. Good Luck. John in NY
Ridr
06-16-2003 07:18:41
There shouldn't be any gap , you want the stripper arm to just rub the bill hook
Dick in Ore..
06-16-2003 19:20:00
 Re: Re: Re: Trick for polishing billhooks? in reply to Ridr, 06-16-2003 07:18:41
Yes, the stripper should rub on the billhook.. It can be bent so it will rub.. Even though it is cast, it is made to bend and adjust. Use a bar or hammer to bend it so it will rub..
Good luck.
Dick
Bruce
06-16-2003 19:48:31
 Re: Re: Re: Re: Trick for polishing billhooks? in reply to Dick in Ore.., 06-16-2003 19:20:00
Just don't hit your finger with the hammer like I did. Duh!!! Also check the bill hook for grooves worn in them. I just had to change mine on my Ford baler becuase they were worn too much. I also have a NH Super 66 and the bill hooks are the same.
