Largest Single deck Brush Cutter
Skinner
06-15-2003 17:54:31
What is the largest single deck brush cutter or shredder available today? (Not Batwing) Largest I've seen is an 8 footer with dual gearboxes. I imagine a 12' wouldn't be too uncommon since they make 6' work off a single gearbox already. What are the disadvantages of a single deck that wide?
And finally, what is the optimum blade speed for any cutter?
JW
06-16-2003 18:06:37
 Re: Largest Single deck Brush Cutter in reply to Skinner, 06-15-2003 17:54:31
15ft deck shredders are the largest that I have seen behind a tractor, I have seen a few pictures of a deck shredder that was mounted on a Windrower and it looked wider than a 15ft. Decks are great if you are on flat land and have gates wider than your deck. If you get a deck on a hilly area you could either high center part of it and the blades start to till the soil, or high end it and have uneven cuts.
Jerry (AL)
06-16-2003 12:23:42
Bush hog makes a 15 foot unit, a 4215.
You can type in bush hog and they have a good internet site.
John A.
06-15-2003 18:54:30
Skinner, I got a 7ft 3pt single gearbox JD It is the largestof this type Ive seen.
JD 707 is a solid deck, 4 row,3 gearboxes-2 swing- center gearbox is just a power divider. Approximently 11ft wide. I have seen a full 6 row shredder, solid deck, various makes.
In the South Plains of Texas in cotton country there are Flail shredders that are 16ft wide,solid decks.
Hope this helps,
John A.
Jeff in TX
06-15-2003 18:30:06
I got a 14' drag-type (hydraulic up and down NO 3 point) with 3 gear boxes and 3 blades. This one is the biggest I have seen.
