Warren 14T Plunger Bearing
Dale in IN
06-12-2003 06:58:23
Warren:
Aimed to answer you a couple of days ago but forgot to look at the plunger that I took apart out of a 14T. and my shop is 12 miles from my home.As Dave from ks has answered you. the 14T is made like the 214. There is a bolt just in front of the pin on the pick up side of the plunger. remove that bolt it holds a strap that is welded to the pin. The pin will only come out that side. The conecting rod has 2 bronze bushings in it. these are not split. 1 bushing presses in from each side leaving about a 1/4 gap between the 2 for grease to travel. If your JD dealer does not have them more than likly any bearing supply dealer can get them for you. As you probably alredy know the crank end has a cap on it and the bearing in it is split. Besure to give these bearing a good greasing every time you use the baler.
