Plow question
bob from NC
06-10-2003 18:35:27
I have a '48 model A, no 3-pt.,and it has a "powrtrol"hydrolic hookup and i was wonderin what kinda old plow would yall recamend for my tractor.It can handle a 3-bottom plow easily i believe. thanx
John51
06-11-2003 11:28:08
 Re: plow question in reply to bob from NC, 06-10-2003 18:35:27
We plowed for years with a '50 A using 3-14 John Deere plows. Tough ground, limestone+clay on the hills. 2nd gear most of the time.
paul
06-11-2003 10:31:21
Soil conditions are different, but where I live it could pull a 3-bottom easily - as long as you don't put the plow in the ground.
--->Paul
kyhayman
06-11-2003 19:43:38
 Re: Re: plow question in reply to paul, 06-11-2003 10:31:21
That's for sure. I can't pretend pull 3-16 with a 5600 Ford in sod ground.
firedog
06-11-2003 07:58:58
Bob,
You could use a JD 44 2x plow, either hyd lift or clutch lift. They came in light frame(10-12),med(12-14) or heavy(14-16) The bottoms could inter-change for width.
You could also try a JD 55 3x trailer plow but conditions are different all over. A JD44 2x14-16 would probably be a good all-around plow for the "A".
Good Luck
Firedog
Wes
06-10-2003 19:41:28
I pull a 3-bottom massey harris with my 47 Model A. I was able to pull it in 2nd and 3rd gear in stubble last year. This spring I plowed up some grass with it and I was in 1st gear the whole time. The sod was thick and the souil was heavy clay in spots. I also had a hill to climb. I would recommend a 2-16, you can move a little faster then.
Wes
