PTO SHAFT LENGTH
seedsntrees
06-10-2003 09:05:40
Hello, I bought a new 3 pt broadcast spreader. When I hooked it up to my 671 FORD, the PTO shaft is too long. Can this shaft be cut in order to shorten the length?
Thanks!
seedsntrees
06-10-2003 20:17:18
 Re: PTO SHAFT LENGTH in reply to seedsntrees, 06-10-2003 09:05:40
Thank you for the advice. I guess that by now all of you guessed that I never had to cut a shaft. NO problem, I understand. It never hurts to ask FIRST!
Shep VA
06-10-2003 09:58:44
Yes it needs to be cut on both sides so that you still have at least an inch to spare on the shafts when the three point hitch is full up. You will need to slide the PTO shaft apart and cut it inside where the shaft slides. 3 point hitch PTO driven machines are the worst about shaft length and you can really tear up a drive line or the tractor if they are the wrong length.
I just cut a shaft that I had with a metal chop saw, but you can use a hack saw if you dont have anything else and then file out the edges and cut one of the shields about an inch shorter than the shaft you cut so you can get everything togeather.
Good Luck
Robert in W. Mi
06-10-2003 16:01:25
 Re: Re: PTO SHAFT LENGTH in reply to Shep VA, 06-10-2003 09:58:44
I've cut down quite a few of them too. The only thing i'd like to add is, i like to have "at least" 2 inches in contact, especially for tools that take some pto power to run. Robert
RayP(MI)
06-10-2003 14:41:29
Shep's right, been there, hacksawed that - worked out fine. Shield was metal, not plastic, so I used a pipe cutter - advancing the cutter wheel very gently to avoid crushing the shield.
