NH 67 stationary cutter angle
Ridr
06-10-2003 07:33:20
OK , I'm not sure if this will sound right but here is hopefully my last problem on this baler. The plunger is square in the chamber and has a straight sharp cutter ,however the stationary cutter (made out of 3/8 steel , maybe this was a past homemade cutter ??)looks like it will need to be majorly shimmed (about 3/8 of an inch )at the top to make it square with the plunger (and baler for that matter)My manual doesn't say or show a good diagram of this ;course it is for a 65 but thats as close as I could find. Does this sound OK to you guys ??
I should add that
06-10-2003 14:45:06
 Re: NH 67 stationary cutter angle in reply to Ridr , 06-10-2003 07:33:20
There was already homemade shims and some washeres behind it, but I realize that doesn't mean that it is correct
