Turning with a haybine
Dave
06-08-2003 05:56:41
Sorry, this may seem like a dumb question but I have never mowed with a haybine. Old NH pulled behind a Farmall 400. How do you make the corners. I am concerned about the pto shaft binding up at a sharp angle. (All I ever mowed with was a mounted mower and I have never seen a guy mow with a haybine) Thanks.
JK-NY
06-10-2003 17:38:52
 Re: Turning with a haybine in reply to Dave, 06-08-2003 05:56:41
Just turn to the right and watch out you dont turn so sharp the rear tractor tire hits the tongue of the haybine. I like using my 4000 Ford to mow hay as it is more manueverable and easier to turn with the 28" rears. Be a little careful on left turns,you dont want to turn too sharp .
TP from Central PA
06-08-2003 18:02:01
I always mowed on the turns until I got about 3 to 4 passes around the field..... .Then I would pick the mower up on the headlands..... .Seems to be easier for us to rake since I only like to have about 3 to 4 windrows on the headlands..... ..Plus you don't have to worry about hurting anything, you may waste alittle fuel, but that is a minor issue.
Hugh MacKay
06-08-2003 08:48:39
Dave: I mowed for 17 years with the same NH haybine and 656 Farmall never lifted the cutter on turns, even when it was more than 90 degree turn. There were more than a few tire skuffs on the haybine tongue. That haybine mowed on average 30,000 bales per year. One item I never replaced was bearings or U joints on the drive line.
DaveJWI
06-08-2003 08:47:25
I use an old New Holland haybine model 460(I think). I just make the corners as needed and have not had a problem with binding, just rattles like crazy.
