Round Baler
Phil in MO
06-05-2003 12:11:42
I'm probably showing my ignorance here, but all I have ever used is the small square or round balers. Getting too old to pick up all those bales by hand in 100 degree heat. I'm thinking of getting a big round baler.
Do I need auxiliary hydraulics to run a big round baler (4x4 or larger)?
I have an older small round baler that doesn't need hydraulics.
What size baler can I use with a 550 Oliver?
Phil
Phil in MO
06-06-2003 04:28:07
 Re: Round Baler in reply to Phil in MO, 06-05-2003 12:11:42
Thanks for the good advice.
Looks like I have enough hp for the smaller sizes. I think the 550 has around 45 hp at the pto. Will need to install remote hydraulics.
I purchased some Beefmaster cattle to start a herd for when I retire and move back to the family farm next year.
I have 350 small square bales stored, but think I will need another 1500 for winter. Since I'm over 100 miles from the farm now, I was looking for a way to put more hay out to feed for a longer period.
Wonder if I could just use my small round baler and put several in a feed ring to last a week or so?
Phil
kyhayman
06-06-2003 19:09:11
 Re: Re: Round Baler in reply to Phil in MO, 06-06-2003 04:28:07
Not sure how many head you are feeding. I'd go ahead and get a 4x4 and put remotes on the 550 or get another tractor. With a 100 mile commute I'd want something late model and reliable.
I currently put out 8-10, 4x4's each week (more or less depending on temperature Jan-Mar for 45 momma cows. I check them every day but make Saturday my feeding day (my 'day job' cuts in on my farm time). Have to do the same at 3 different farms and I barn store my rolls so it takes a little while to get them fished out.
JMS/MN
06-05-2003 22:23:15
It depends on the baler..... all need a remote to run the tailgate, some need another to run the twine arm.
Casey in Ky
06-05-2003 20:49:33
Like James says, you will need 1 remote for the tail gate, other than that there is no other need.
Hesston does make a a smaller round baler(about a 500lb roll, I think it's like a 39inch by 44inch or something like that) that they say requires a minimum of 35 pto hp. If your not planning on rolling to much hay, you might want to look at this one. I think it's a model 530?? But I'm not for sure on that as I'm not real familar with Hesston equipment.
Other than that I'd say look at a NH 630, 634, or 638(pretty much all the same baler, just newer model numbers). They are a lighter made machine, but are a decent little 4x4 baler that makes about 800 lb roll. You should be able to pick a good used one up for between 5 and 8 thousand. Hope this helps a little.
Casey
Carter and Carter Machine
06-06-2003 02:18:56
 Re: Re: Round Baler in reply to Casey in Ky, 06-05-2003 20:49:33
third party image
There is not a better value out there than a Vermeer 5400 Rebel baler. Takes 40 HP and makes a 1200 LBS. This baler will bale haylage, corn stalks or any thing you can windrow. Fully Loaded, serviced and ready to go to the field, we sell them for $11,500.
James in NC
06-05-2003 14:03:25
You will need 1 set of hydrualics, to raise the tailgate. Twine can be but on with and electric switch, or rope on some of the older model balers. At least 45hp is required to run the smaller round baler. You will probably need more if you are working on hill sides.
James
