New holland 68 baler
mark
06-08-1999 14:04:58
I just bought a new holland 68 baler.
I DID NOT GET A BOOK YET FROM THE OLD OWNER AND THE STRING WAS PULLED OUT OF THE KNOTERS AND I HAVE NO IDEAL HOW THAY GO ON.
SO CAN SOME ONE TELL ME(IF THEY IS A EASY WAY TO TELL SOME ONE)HOW TO REKNOT THE KNOTER.
pete williams
04-08-2001 03:16:26
 Re: new holland 68 baler in reply to mark, 06-08-1999 14:04:58
hi, saw your reply to someone regarding new holland 68 baler, i have just acquired the same type of baler and need a manual to get it started. Help please!
it breaks cotter pins and there is play in the gearbox?
Note correct e-mail address [email protected]
Thanks..
Tim(ny)
06-09-1999 06:48:48
Mark, its even easier than C.C. said. Thread thru all the eyes, thru the ends of the needles, and tie the ends off to anything handy(look on the inside of the twine box cover, sometimes there's a diagram of how to feed the twine). Then start eating hay. It will take it from there, you don't have to cut the string, except for neatness sake. You can pull the trip rod to engage the knotter and then as soon as you engage the PTO the needles will come up and set the string in the knotter. This will start your first bale. With no back pressure, the first bale will be a mess. Wait for the 3rd or 4th bale when the back pressure is equalized and see if you want to adjust length and back pressure. Happy haying.
micheal
06-09-1999 05:50:56
Hey tryed to email you but did not have your email address. email me and I can tell you how. Also have a manuel for one. Could photo copy for you. email me and should be able to get you baling again.
micheal
pete williams
04-07-2001 11:20:26
 Re: Re: new holland 68 baler in reply to micheal, 06-09-1999 05:50:56
hi, saw your reply to someone regarding new halland 68 baler, i have just acquired the same type of baler and need a manual to get it started. Help!
Pete.
C.C.
06-08-1999 14:38:51
Mark,
I don't know if it's same but on my NH 565(a lot bigger and newer machine) all you have to do is thread the twine through everything up to and thru the needles. Then tie both of them off on a small plate that crosses right behind the needles. Then run some hay thru until the needles trip and needles poke both sides through the knotters. Then all you have to do is cut the excess off (what was tied to the small plate) and you ready to bale. But like I said, I don't know if it's the same on a 68. I imagine that it would be, but not for sure. Hope this helps. Casey
R.M. in Ont.
06-08-1999 17:39:44
 Re: Re: new holland 68 baler in reply to C.C., 06-08-1999 14:38:51
It has been many years since I had to rethread a
baler but I think you're right. We had IH 45 baler
to begin with and I think they worked the same way.
Right now I'm glad to be too old to even think
about haying.
