Jd 630
joe
05-31-2003 17:37:17
I would like information on implements that can be used with this tractor. More specifically what size plows to use,bush-hog and disc plow. Any other accessories that work well with this tractor would be very helpful. thanks....
Leroy
06-03-2003 06:49:24
 Re: jd 630 in reply to joe, 05-31-2003 17:37:17
48 PTO HP, rated 3-4 plow, 10' or 12' disc or field cultivator, 9' haybine, 4 or 6 row cultivators, 2 row mounted corn picker
Don
06-01-2003 06:31:19
Looking at the service manual, it says it can handle a 3(14")bottom moldboard plow under normal soil conditions. We used to use it to till over 60 acres per year with the 3 bottom plow. We also pulled an 8' JD disc with the 630. As far as mowers, I currently use it to run both a JD #5 sicklebar mower (and it works great) and also a 3 pt rotary mower. When finding a rotary mower look for one wider than the rear wheelbase of the tractor.I know the tractor can handle up to an 8' pull type rotary mower.
