JD #5 mower
Chuck in Ks.
05-30-2003 21:28:15
I recently purchased the mower and need to know what type and weight of oil to put in
the gear box?
I want to change the oil.
Thanks
Chuck
C
06-06-2003 22:06:09
 Re: JD #5 mower in reply to Chuck in Ks., 05-30-2003 21:28:15
#90 is OK. The oil usually leaks out the seal behind the flywheel. Grass gets wrapped up in there.
A word of wisdom.... Do NOT overtighten the bolts holding on the covers (top and rear bottom). I see many of those mowers where Mr. Armstrong broke all the ears off the covers by over tightening the bolts.
Dan
06-01-2003 10:24:44
Most of these tend to change their own oil about once a year when they sit through the winter. Nothing to get it dirty in the case so just think it is a matter of keeping everything slick in there. Believe it does call for 90 wt oil but think 140 would work also.
Delbert
05-31-2003 06:17:46
Put 90 tranny oil or a little heavier if it leaks a little. Don,t know how much maybe a quart. Fill to plug chances are 60/40 that it,s the same oil that came in it. Have a gooden.
