John Deere 4B Plow
Ryan
05-30-2003 15:58:16
I got my 4B plow out today after it had been sitting outside for over 30 years. I fixed it up and put new tires on the front wheels. The clutch wheel moves in and out about 1/2". Is it supposed to do that? Also, the rear wheel is froze up. I have the rim and all that off but the hub won't break loose. Any suggestions? Thanks, Ryan
Bob Collins
05-31-2003 14:09:13
 Re: John Deere 4B Plow in reply to Ryan, 05-30-2003 15:58:16
Ryan, 1/2" is a little too loose for land wheel end play, take the cap off and adjust by turning the collar so the lynch pin fits in a different notch. If it is fully adjusted you may need to add a 1 3/4" i.d. washer to take it up. Never saw a tail wheel frozen that badly, can you get any grease forced in? Maybe try a little heat then grease. Good luck.
Ryan
05-31-2003 19:51:19
 Re: Re: John Deere 4B Plow in reply to Bob Collins, 05-31-2003 14:09:13
Bob, Thanks for the help I'll give it a try. Ryan
