Why a Oliver baler ties good on a new bale of twin
Bob
05-27-2003 11:17:53
I am going to use my neighbors Oliver baler this spring to bale my grass hay. He said is works good on a new bale of twine and doesn't miss a tie untill the bale is half used up. Does anyone know why it would do that or have any suggestions for what to look for.
Thanks,
Bob
mg
06-02-2003 11:37:09
 Re: Why a Oliver baler ties good on a new bale of in reply to Bob, 05-27-2003 11:17:53
You have to have a certain amount of tension on the string not to much or the string will break. I lost a lot of sweat before i figured this out.
Bret
05-28-2003 05:48:46
Twine tension for sure. BTW- out local baler expert says 90% of knoter problems go away with the plastic twine. Much more uniform than sisal and just works better. That being said, I still use sisal 'cuz plastic is a bear to get rid of.
kyhayman
05-27-2003 18:38:34
I agree with Tim that it is probably you tension. It always seems to me that the twine is under more tension at the center of the ball and less as you go out.
Could also use some adjustment in the tucker fingers I'm guessing. Almost have to get the book and sit down to adjust out knotters. I usually spend a half day every years right after I finish first cutting alfalfa (want them polished off nice and clean). There are about 5-6 things to adjust and need to set to .30" or less with tensions in the 5# gradient.
tim[in]
05-27-2003 14:29:16
could be you need more tension on the string or maybe not as much. the more i think about it and the way twine is wrapped in those bales i would guess the first part which comes from the inside is easier to come out.
