Vermeer 605C big baler
Travis
05-26-2003 12:14:04
Hey all, just thought I would throw this out and maybe someone else will know before I am able to figure it out and save some time. I bought a "fencerow" 605C last fall to fix up and use this summer. Well, have gotten behind and just now am able to work on it. Okay, everything works, and I know it will bale, but I need to figure out why the belts will not run straight, I put some missing bolts into the belts guides, and that helped to straighten things out a bit, but I still have one or two belts that want to ride off on the side, any ideas?? Thanks
Michael D Shelton
07-08-2003 16:13:29
 Re: Vermeer 605C big baler in reply to Travis, 05-26-2003 12:14:04
i have a 605c i have problems starting a bale.the longest is 36.7in and the shortest is 36.2in do you know what the exact lenght is supposed to be?
James in NC
05-29-2003 14:46:11
If the baler is empty this is not a problem. If there is a level bale in the baler then ther is a problem. Email me I can probably help. I'm a dealer.
James
thurlow
05-27-2003 13:03:07
Travis; is this while you're baling that the belts won't run straight?; if it is, it's probably because you haven't 'mastered' the windrow weave; i.e. keeping the same amount of hay all across the bale; can be big problem with small windrows; large windrows better; double windrows best..... ..
paul
05-27-2003 11:37:16
In addition to the belt length, is everything true & straight for the rollers? If something of the frame or door got twisted, the belts will want to run off to the side.
I'm thinking the C model is the last of the closed throat design - they are kinda fussy about having dry hay & getting the bale started.
--->Paul
Mike
05-27-2003 05:17:15
Just a thought but are they all the same length. I've never had a problem with it but have heard if a belt is longer than the others it will "wander" around. I've got an older John Deere and the manual says they have to be within two inches of each other.
Good luck.
