Need help with JD 336 needle carriage
Tim(nj)
05-24-2003 18:55:37
I no longer have a JD 336 but somebody asked me to replace some broken needles in one. (probably she figured having fixed 2 of my own I'd know something). Well, turns out the needle carriage is bent, too, and needs replacement. Here's my problem: I never had to take a needle carriage off of either of my 2 336s when I had them. I took out the bolts that hold the carriage to the bale case, but there are bushings in there that I can't get out, which are preventing me from removing the carriage. How do I get the bushings out? Or do I have to spread the pipe frame of the carriage apart to go over the bushings?
RickB.
05-25-2003 03:15:27
 Re: Need help with JD 336 needle carriage in reply to Tim(nj), 05-24-2003 18:55:37
I work on NH balers, not Deeres, but here are my thoughts. The bushings should be free in the needle bail and the mounts. The bushings should be longer than the bail and mounts, allowing the mounting bolt to trap the bushing and keep it from turning, keeping any wear between the bushing and bail (grease as well). If the bail is junk, cut it in half below the chamber, remove it, and press out the bushings, or replace them as well. A NH baler is constructed this way, I would expect a Deere to be similar given your description.
