King Kutter Disc
DAB in KS
05-22-2003 15:17:45
I am thinking of buying a 6.5' 3pt disc at TSC. Is the box frame model worth the extra couple hundred dollars compared to the angle frame model? I have been trying to find a decent used 3pt disc of this size, but I am running out of time. Thanks for any thoughts.
Dave in Mo
05-23-2003 10:14:35
 Re: King Kutter Disc in reply to DAB in KS, 05-22-2003 15:17:45
You didn't mention the size of your tractor. I have an 8N and a Case VAC and the 6.5 footer is all they can really handle. The heavier one is by far a better deal but a 20 HP machine won't really pull it. I buy new stuff because I can get parts readily. Last Fall I had to repair my disc because some relatives whacked it into some trees turning. It was no prob getting back into service.
DAB in KS
05-23-2003 14:32:26
 Re: Re: King Kutter Disc in reply to Dave in Mo, 05-23-2003 10:14:35
Sorry about that. I'll be pulling it with a Ford 860 w/45hp. As long as I have enough weight I think I should be able to pull it ok.
MarkL
05-25-2003 14:21:05
 Re: Re: Re: King Kutter Disc in reply to DAB in KS, 05-23-2003 14:32:26
I had the same question about a week ago. Used discs I've seen looked pretty beat up. I bought the heavier box-frame Kutter disc, for durability as well as weight. Even it could use more weight. My Allis D-17 (45 horsepower or so) can pull it fine, but lacks down force on the 3pt, so going too fast causes skips. Cuts well as long as I don't hurry, but I may try chaining a railroad tie on top of the frame, as someone here suggested.
Tom-Pa
05-22-2003 15:28:41
The box metal frame is a heavier frame and will help with making the discs cut in better..with the angle iron frame, I feel it is too light. I have the angle frame and run it with a railroad tie on it to help it cut in better..
But, as always, go with what you can afford and you can always rig a weight up if need be..If you can do it, Get the heavier one..
Good luck with what ever you decide.
Tom-Pa
RayP(MI)
05-22-2003 19:47:29
 Re: Re: King Kutter Disc in reply to Tom-Pa, 05-22-2003 15:28:41
Right on Tom! Dab, you might want to look around at auctions, or used equipment dealers for a "name brand" disc. Many are better constructed. I'm using a 8 1/2 foot MF, and wishing it was even heavier!
DoubleR
05-25-2003 06:59:52
 Re: Re: Re: King Kutter Disc in reply to RayP(MI), 05-22-2003 19:47:29
I pull a ten ft. A-C wheel disc on new plowed ground or anything else I've ran into easily with 46hp I-H. Some ground, I don't even plow depending on what was planted previusly. I paid 300bucks for it at a auction and it cuts alot better than any 3pt disc I've seen. For what its worth.
