John Deere 290 planter
JDMAN(mo)
05-19-2003 18:42:53
Trying to put a 290 in operating condition with some things missing. What is the little lever on the gearbox with the spring attach supposed to hook too, and what does it do?Russ
CharlieG
05-24-2003 14:50:54
 Re: John Deere 290 planter in reply to JDMAN(mo), 05-19-2003 18:42:53
Can't find my old book right now so I'll take a stab from memory.
On the left side of the gearcase is a lever with a hole in the top and a roller on the bottom. Through the hole is a hook attatched to a spring that goes to a bracket on the front of the gear case. The roller engages a rocker that's on the six sided shaft that opens the valves via rods to the row units. As the check wire hits, it moves all this stuff and drops seeds. There is a small rod that extends toward, and just above the rocker that has a finger on it about 3 in long. This can be moved to hold open the valves and is done when drilling.
Hope this helps a little.
JMS/MN
05-19-2003 23:08:55
The lever on the gearbox is likely used to set kernels per hill- probable 2,3,4?, if you see those numbers there?
JMS/MN
05-19-2003 23:06:43
