PTO hookups
steve
05-18-2003 20:19:10
I am interested in obtaining a couple of pieces of equipment. I would like a woodchipper attachment for my tractor, a tiller type attachment if it exists, and a wood cutting attacment. Anyone know where to get these items?
Paul Janke
05-20-2003 05:54:03
 Re: PTO hookups in reply to steve, 05-18-2003 20:19:10
Are you referring to a buzz saw for cutting wood? They are usually anywhere from a 28" to 36" blade. Belt drive is a lot more common because most of them are from an era when most tractors had belt power. PTO drive saws are around, but are usually lots more money because they include a right angle gearbox and v belt drive. Many of the flat belt saws have been changed to PTO by just putting a PTO shaft in place of the pulley. I don't like doing that because 1) the saw runs slower than designed for 2) there is nothing which can slip if something binds in the saw 3) The saw usually runs the other direction, so unless you rethread the shaft the other direction, the power tries to remove the saw instead of tightening it.
Don-WI
05-18-2003 20:33:14
What type of tractor do you have? There are many different tiller brands and sizes. For wood cutting, do you mean a log splitter? If so, they are ussually run off the tractor's hydraulics. The best wood chipper I ever used on my tractor was our old fox chopper, until a small steel rod went in and broke the knife bolt the rest of the way(the bolt was almost gone already, after looking at the part of the bolt that was still in it). Ended up snubbing my 1755 diesel in a heart beat, with a little bit of a *ping*, and it twisted the pto shaft that couples to the tractor. Bought a used one for $200, and now I have a newer Fox 1000 that I use for harvesting now, and I am thinking about selling the old fox, parts and all.
Donovan from Wisconsin
