Owatonna Haybine 216 model
Paul S.
05-18-2003 18:51:08
I just bought a owatonna 216 haybine and was woundering if anyone has any experience running one. It's all complete and all the bearings seem to be good,but when you run it, it shakes like it's gonna fall apart,the pitman arm looks ajustable but I don't see how that would effect any thing but how the sickle meshes with the guards. Is the shaking just a design flaw or is it fixable,I paid $110 at Auction for it,now I am starting to see why it went so cheap!
Jarhead
05-21-2003 17:32:52
 Re: Owatonna Haybine 216 model in reply to Paul S., 05-18-2003 18:51:08
I had one of these once. On the underside their is a frame work that runs from the main frame to the wheels. On these frame rails are some connecting rods that hold the header in position. If these break or rust away the pitman will strike the hitch frame on a inside turn. This can bend the arm or at least shear a pin.
Also their may be a dapener in the gearbox that was put back wrong.... Hope this helps...
