McCormick-Deering #7 Sickle Mower
Dennis Johnson
05-18-2003 17:46:12
I have been using my sickle mower to cut around the pond but ran into a problem last week. I dont have a manual(have ordered one) so I dont know what the names of different things are. Here goes..I metal round wheel is attached to the gear box and the wheel has a metal rod attached to the round wheel. There is a 2 part "clamp" which holds the end of the bar which makes the cutters move move back and forth. The clamp , I think, had a bearing in it . My clamp is worn out and wobbles around the rod coming out of the wheel. In fact the rod appears to have been gouged out by the bearing on the clamp. If I have made sense and someone has any parts which would help me I would appreciate hearing from you ....
Dennis
Old Iron
05-19-2003 12:50:46
 Re: McCormick-Deering #7 Sickle Mower in reply to Dennis Johnson, 05-18-2003 17:46:12
Dennis,
Please e-mail me your snail mail address. I'll print out a copy of my #7 manual and drop it in the mail for you.
Old Iron
Dennis Johnson
05-19-2003 18:05:21
 Re: Re: McCormick-Deering #7 Sickle Mower in reply to Old Iron, 05-19-2003 12:50:46
Thanks, Old Iron. I sure do appreciate this..
My mailing address is : Dennis Johnson
16 Alford Mill Rd., Bunn, NC 27508. Thanks again.
Dennis
Okla/kans Bill
05-19-2003 10:12:04
Ill tell you a place where to go, but I sure dont envy him what with your discription of things. The wheel, is the flywheel. The rod attached to it, is the pitman rod. It goes to the sickle.call 717 543 5136. Tell then Oklahoma Bill sent you. Good luck
Dennis Johnson
05-19-2003 12:38:22
 Re: Re: McCormick-Deering #7 Sickle Mower in reply to Okla/kans Bill, 05-19-2003 10:12:04
Bill, U B D Man!!!. I have already called and they have the parts I need..
Thanks
Dennis
