JD F145 4-16 or AC model 2000 4-16 ?
huthut
05-18-2003 11:36:36
Want to get one of these plows for my JD 3020 in sandy soil. The JD might be in slightly better overall shape, however the AC looks to be a bit heavier built with the monoframe construction. Will one handle cornstalk trash better? Any feedback is appreciated.
THanks
ghostrider
05-19-2003 06:10:05
 Re: JD F145 4-16 or AC model 2000 4-16 ? in reply to huthut, 05-18-2003 11:36:36
I'll give it a shot. Had an f145 6x16 plow. It would plug up in heavy wheat stubble if plowing deep. There is an f145h high clearnace model. I think I've seen a 2000 ac plow. Looks like it would have plenty clearance. If I'm not mistaken, it had a big square plate fastened to the monobeam that did all of the pulling. This AC plow was a 6x16. The plate had been pulled off and rewelded many times. Might not be under as much stress on a 4x16. We had lot of problems in the rear lift linkage on our f145. Seemed to be undersize for 6 bottoms. I haven't seen that type of problem with the 4 bottom f145 models. Hope this helps.
paul
05-19-2003 08:48:13
 Re: Re: JD F145 4-16 or AC model 2000 4-16 ? in reply to ghostrider, 05-19-2003 06:10:05
Don't know that I've seen an AC, but that's about right on the 145. They do plug up on stalks. Pretty good plow otherwise in the 4-bottom.
--->Paul
