IH Plow Coulters
smirkey
05-06-2003 13:06:19
i have a 540 fast hitch plow for the f-450 and the original coulters are broken. are there any newer type of IH coulters that are spring loaded that would fit on my 540? which plow models started using a spring coulter? i think my original ones break because of the rocks in the fields.
Tim(nj)
05-06-2003 15:16:57
 Re: IH Plow Coulters in reply to smirkey, 05-06-2003 13:06:19
My 540 actually has John Deere coulters on it! All you need is the same shank diameter. I think even Oliver/White spring coulters will fit in the clamps. The 710 was the first IH with the spring coulters. Don't get the curved blades, though, they don't like rocks either.
Hugh MacKay
05-06-2003 16:42:39
 Re: Re: IH Plow Coulters in reply to Tim(nj), 05-06-2003 15:16:57
I had cushion spring coulters on my 510 - 5x16 semi-mount. I don't think there was a lot difference in timing of introduction of 510 and 710. My plow was new in 75, they had been out a couple of years then. Spring cushion coulters are almost a must in rocky ground. 1 coulter may have lifted a 2 bottom plow but not 4, 5 or more.
