Whats the purpose of a disk plow
markct
05-06-2003 05:23:24
are disk plows somehome better than moldboard plows in some aplications? or just someones variation of a design? i have never seen one used around here (connecticut) but plenty of regular moldboard plows.
Burrhead
05-06-2003 16:05:46
 Re: whats the purpose of a disk plow in reply to markct, 05-06-2003 05:23:24
a disc plow is better in hard ground and in ground with roots and/or rocks, like in new ground.
I never had any problem like Ethan had with a disc plow not going as deep as a bottom plow. In fact the disc plow will run deeper in hard ground like clay than a bottom and the disc will completely turn the soil upside down if you have it set right.
Tim(nj)
05-06-2003 20:51:29
 Re: Re: whats the purpose of a disk plow in reply to Burrhead, 05-06-2003 16:05:46
Possibly what Ethan calls a disk plow is actually a "harrow plow" or "one-way" in other areas of the country? Which would explain why it didn't go as deep as a moldboard plow, as one-ways weren't for deep tillage, just mixing surface residue into the soil.
Burrhead
05-06-2003 16:05:29
ethan
05-06-2003 12:33:27
A disk plow will not cut as deep as a plow.but a disk plow will cover more ground then a plow and do a pretty good job at cutting up the weeds.
