STUMPED! NH 467 haybine problem
Tim(nj)
05-30-1999 20:16:17
A friend of mine has a NH 467 Haybine. Always shedded, nice shape, works great EXCEPT that when the upper roller raises up to clear a slug, on the right side (standing behind machine), it won't come back down. He has to shove it down with a prybar. Didn't seem to matter if the rollers were set tight or loose. I never used a 467, and the 477 that I had didn't have the same setup for roll tensioning. Anybody have any ideas? The manual hasn't been much help.
RickB.
05-31-1999 04:15:00
 Re: STUMPED! NH 467 haybine problem in reply to Tim(nj), 05-30-1999 20:16:17
Not intimately familiar with a 467, but I'll bet the rh roll bearing carrier is bound up on the pin or weldment that it pivots on. Release the roll tension, get some good penetrating oil. Spray the pin/bushing area and work the roll up & down. It may be necessary to apply heat to the area, or if it is really stubborn, it may have to come apart & get cleaned up. If you choose this route, sacrifice the roll bearing & lock collar, it will be very hard to save it.
