MF MOWER
TOM
04-30-2003 17:56:32
I have a MF 41 dynabalance 3 pt hay mower which has a broken sickle driver ; My dealer says mf don't make the driver anymore.The part which is broken is the oval where the sickle head fastens in (piece that broke was lost) the # of it is 581-271m1 does anyone know where I might get one new or used ?thanks for any help TOM
src
05-05-2003 05:44:08
 Re: MF MOWER in reply to TOM, 04-30-2003 17:56:32
I have one of those with a broken frame. If you
can post a picture of the part you need, I'll look to see if mine is the same.
TOM
05-07-2003 18:47:25
 Re: Re: MF MOWER in reply to src, 05-05-2003 05:44:08
I don't know how to post a picture yet as I am new at computers""" the part I need is where the sickle fastens to the head what drives the sickle ,The hole in this part is tapered larger at bottom then at top ,it is probably malable steel . the part is kind of shaped like a pear aprox 2.5 " on one end and around 4-5" on other aprox 6-8" long 1.2-2" wide hope this helps discribe it. TOM in Iowa
hay
05-02-2003 03:27:16
i have a MF 31 sickle mower and the local dealer has essentially told me that MF does NOT make parts for sickle mowers this old anymore. i would assume that would be true for most of them. best place to look would be a tractor boneyard or some of the multi brand used tractor/implement dealers. if you have a idea of what the parts look like or a parts manual, then maybe a machine/welding shop could make one for you.
