Krone disc cutter
Heath
04-29-2003 13:32:05
Not really famaliar with Krone brand. Local guy has a 9ft krone rotary cutter model am283s. looks to be a little worn with some rust but not too bad. He's asking 2500. Is this a good price?
thanks
Heath
James in NC
04-29-2003 18:02:38
 Re: Krone disc cutter in reply to Heath, 04-29-2003 13:32:05
The 283 is a current model and sells new for $7,000 to $7,500. Check for wear in the gears. The nice things about the Krone is that there is no inner shoe and the direct drive line. (no belts)
Heath
04-30-2003 07:44:41
 Re: Re: Krone disc cutter in reply to James in NC, 04-29-2003 18:02:38
Is there an easy way to do this(check the gears), or do I need to take it apart?
James in NC
04-30-2003 09:45:26
 Re: Re: Re: Krone disc cutter in reply to Heath, 04-30-2003 07:44:41
I would just see how much play there is in the cutting discs. Put your hands on a disc and turn until the other discs start moving. I little play can be expected but a quarter turn is to much. You can check out the Krone web site for more info on their mowers.
http://www.krone-northamerica.com/
Heath
04-30-2003 13:35:24
 Re: Re: Re: Re: Krone disc cutter in reply to James in NC, 04-30-2003 09:45:26
Cool. I messed with it a little and everything seems pretty tight. The surface is a little rusty but all the discs move rather easily. They told me on sat. that i could hook it up and try it out. Is there anything in particular I should look for?
Thanks for all the help
Heath
James in NC
04-30-2003 14:14:54
 Re: Re: Re: Re: Re: Krone disc cutter in reply to Heath, 04-30-2003 13:35:24
I would run it and listen for any bad sounding noises. Krone mowers are known for being fairly quiet. Maybe check the universal joints.
Mike (WA)
05-01-2003 12:23:33
 Re: Re: Re: Re: Re: Re: Krone disc cutter in reply to James in NC, 04-30-2003 14:14:54
You should actually cut some grass with it (as opposed to just running it)- bad bearings or ujoints may not make their "noises" unless you put it under load.
