Wisconsin engine suggestions?
Tom A
04-29-2003 04:43:10
Just bought an old NH 66 baler with a Wisconsin 2 cylinder engine with electric starter.
Previous owner says when last used (2-3 years ago), the engine ran well once it started, but that it was very hard to start...he said the magneto needs a rebuild but he really recommended switching to a coil.
Over the next few weeks I'll be cleaning up the engine and have 2 questions, one general one specific:
1) Is the starter probably 6 or 12 volts?
2) Any special things or peculiarities I should be aware of on this engine? (I know engines fairly well, but have never seen a Wisconsin before)
thanks in advance for any and all help!
Tom
Roger
04-30-2003 11:39:29
 Re: Wisconsin engine suggestions? in reply to Tom A, 04-29-2003 04:43:10
The most important thing to look for on an air cooled engine is weak valve springs. The heads run a little hotter on an air cooled engine and the springs get weak. New valve springs solved my starting problems more than once.
Dan Pa.
04-29-2003 16:56:48
6 Volt Pos.Gr. Check spark, if it is blue & strong it is OK. Check compression, could be valves .
paul
04-29-2003 04:56:28
More familiar with the V4's - if tuned up they run all day, but don't start when they are hot.
I need the magneto tuned on my v4 also (dies if the temp is over 85 degrees, I'm assuming something is marginal in there), and the fuel pump leaks a lot. Need to start looking for parts be4 swathing season!
--->Paul
You sound like me posting that. lc
04-29-2003 19:34:18
 Re: Re: Wisconsin engine suggestions? in reply to paul, 04-29-2003 04:56:28
My swather sounds like it runs exactly like yours, except I replaced the fuel pump last year and the points are the only thing that gave me trouble after. The pump fixed all the starting/dying problems.
Val
04-29-2003 10:18:38
Paul, Are you sure it's the coil causing the problem at temps over 85. On my swather with the v4 there is a switch that protects the engine from overheating by shutting it down. I have to deal with this if I'm working it hard at 85-90 degrees. Not sure if all were set up that way or not.
paul
04-29-2003 11:34:04
 Re: Re: Re: Wisconsin engine suggestions? in reply to Val, 04-29-2003 10:18:38
My uncle had that problem with his, aluminumn heads. Mine is all cast iron, very old, don't think it has such a switch. My uncle delt with his by romoving/shorting/bypassing the switch & driving. :)
Good thought tho, & I could be proven wrong. :) Could you tell me where the switch would be located if there was one?
--->Paul
lc
04-29-2003 19:37:57
 Re: Re: Re: Re: Wisconsin engine suggestions? in reply to paul, 04-29-2003 11:34:04
One mine it's on the right side head if your facing the fan. It sticks out of the cooling tin straight up and in plain view.
lc
04-29-2003 19:37:56
