John deere 4 bottom plow questions
markct
04-28-2003 19:10:36
i have a just gotten a john deere 4 bottom plow which somone had let the shins wear down too far and it wore down the part behind it, i believe its called the frog, thats not much of a problem tho i plan to cut out some steel and form it to fit in there and weld and grind it back to its original shape, however i do need to get new shins and the other part that is below the moldboard, i think its called the share? i know it is a 14 inch plow but thats all, i dont see a model number anywheres on it, i have looked in a few different catalogs for parts and i see that they just list parts as john deere 14 inch plow, were most all the plows the same or am i missing something here? i need to get the parts but dont want to end up with the wrong ones, also where might i be able to find a set of coulters for this plow, mine are missing
BigMac
04-29-2003 09:34:39
 Re: john deere 4 bottom plow questions in reply to markct, 04-28-2003 19:10:36
Mark,
I bought new shares, shins, moldboards, and trash plates for a early '60's John Deere F145 4-14 plow from Shoups in Illinois. In the catalog all parts were list as John Deere 14" and everything fit perfectly. Pricing was very good.
BigMac
markct
04-29-2003 09:43:53
 Re: Re: john deere 4 bottom plow questions in reply to BigMac, 04-29-2003 09:34:39
thanks, that is where i had been looking to buy them, shoups, and i am pretty sure my plow is from about that era, i actualy have 2 plows, a 3 bottom and a 4 bottom, the 3 bottom has 2 complete bottoms on, and the 4 bottom also has 2 complete bottoms on it, i am hoping to put together the 4 bottom outa the 2 plows,both are worn out tho and will require a good deal of welding on the frogs,but i gota get a set of shins to use as a template to tell how far out the frogs are supposed to be,is shoups pretty quick with there delivery time on orders?
BigMac
04-29-2003 18:03:12
 Re: Re: Re: john deere 4 bottom plow questions in reply to markct, 04-29-2003 09:43:53
Mark,
As others have stated, Shoups is fast on delivery and they appear to have everything in stock that they manufacture. Prices are a fraction of Deere over the counter. Good quality parts and thick steel.
BigMac
RickB.
04-29-2003 16:27:30
Mark is the 3 bottom a trailer or 3pt? If you want to get rid of the frame and or leftover parts after you take the bottoms off, contact me. I think you are within driving distance.
paul
04-29-2003 11:39:43
Shoups is pretty good.
So is this a 145 JD plow? semi mounted? I have a 4 bottom 14" parts machine, & a 4-16 in better shape, altho it could use a good going over as well....
There were many different types of coulters on them, a flat vertical holder, the typical round shank, & then there were cone coulters as well. In spring loaded & shear bolt versions.
So what are you wishing for? I think a neighbor looked for a cone unit a couple years ago at the dealer, it would have been 3 times the value of the plow, and was no longer available.
--->Paul
markct
04-29-2003 21:59:32
 Re: Re: Re: Re: john deere 4 bottom plow questions in reply to paul, 04-29-2003 11:39:43
where are you paul, i might be interested in one of those plows if your not too far away, also my coulters are the round shank mount type, and it is a full 3pt mount plow, it made the front a bit light coming home with it on the back!
