NH 66 baler tires -- help!
Tom A
04-28-2003 04:02:26
Just bought a New Holland 66 baler at auction (unplanned buy, you know how that goes).
I thought I remembered that one tire was supposed to be different size from the other...can somebody tell me which one is supposed to be bigger and which is smaller? The right tire (as you face the direction you are baling in) rubs against the frame, and it appears the bushings/bearings on both tires are badly worn causing them to sag in. So I'm not sure if the rubbing is due to worn bushings or the wrong sized tire. Can anybody tell me which is supposed to be smaller, and perhaps what size it should be??
thanks,
Tom A
JMS/MN
04-29-2003 00:33:00
 Re: NH 66 baler tires -- help! in reply to Tom A, 04-28-2003 04:02:26
The left side of the baler carries more weight, so it has a bigger tire. Right side carries only the pickup, etc, and is smaller.
Leroy
04-28-2003 18:21:51
Bale Chamber side 6:00 X 16", Pickup side 5:00 X 16", wheels can be reversed for wider spacing, have 2 balers setting in yard now to make one out of, one has a 7:50 X 16 on bale chamber side, other has a 2:35 X 16 on
Kelly C
04-28-2003 05:34:09
On my NH 68. The tire on the plunger side is bigger. It is a 6ply tire. The one on the pick up side is slightly smaller and it is a 4 ply tire.
On my 68 ( yours may be simular). You can adjust the angle that the wheel rides. There are bolts on the under side of the axle. These change the angle of the wheels.
thanks!
04-28-2003 08:00:59
 Re: Re: NH 66 baler tires -- help! in reply to Kelly C, 04-28-2003 05:34:09
I appreciate the quick answer.
Tom A
