JD # 5 mower question.
Kelly C
04-23-2003 18:18:21
Well it now time to get this thing going.
What size rivets do I need to buy to replace the cutters?
Also any one know where to get a 4 x9 tire for the thing?
Thanks
Kelly
Bob
04-25-2003 05:34:02
 Re: JD # 5 mower question. in reply to Kelly C, 04-23-2003 18:18:21
Could also get the tire from www.gemplers.com. I've been pleased with their products and service.
Kelly C
04-25-2003 20:21:49
 Re: Re: JD # 5 mower question. in reply to Bob, 04-25-2003 05:34:02
Thanks for the info. I ordered the tire from them. I could get it online. Miller Tire I needed to call in to order.
3401 4.00x9 4-ply I-1 Rib Implement Tire 1 $27.00 1027 4.80/4.00x8/9 Combo Inner Tube - TR13 Valve Type 1 $8.25
Ravgardner
04-25-2003 05:06:09
Kelly, I bought a nice replacement tire for my No. 5 through Miller tire. They had a replacement tube as well. I bought the longer rivets at TSC, and the shorter ones through Deere. I like the Deere quality better. I also bought the bolts for holding the sections on the bar, then got cold feet and stored them away. I decided I wanted to do it the old original way and rivieted all new sections on my bar.
http://www.millertire.com/
Ravgardner
04-25-2003 05:11:02
 Re: Re: JD # 5 mower question. in reply to Ravgardner, 04-25-2003 05:06:09
One additional bit of information. Tractor Supply Company, TSC, sells complete cycle bars for JD mowers for about $55 dollars. I ordered one so I could look it over to be sure it is what I want before I buy. A spare bar is good idea. Deere sells them for around $80.
Kelly C
04-25-2003 20:05:26
 Re: Re: Re: JD # 5 mower question. in reply to Ravgardner, 04-25-2003 05:11:02
Groovy!!! I see there is a TSC in South St. Paul.
I might have to take a lunch break around there some time.
Dan
04-24-2003 07:48:22
You may be able to get the tire from a place that handles lawn mower parts or a tire store could order one. Took one off of an old JD #56 riding mower for my #8 mower. Rivets are easy to come by, get some long ones for the cutting head also. I prefer to use bolts as the are easier to replace in the field. They are tye type used on swathers but will generally work with a mower also.
Dan
04-24-2003 07:43:20
Rick(MN)
04-23-2003 20:21:33
Just run down to the JD dealer in Isanti and they will set you right up with the proper rivets.
