Will sickle guards bend or break?
James
04-23-2003 15:18:48
I have a New Holland 456 sickle mower. All the guards are brand new. One is slightly low in front and another is slightly high. If I hit these hard enough with a hammer to move them (like the manual says), will they bend into the correct height, or will they break? These are guards without replacable ledgers, $12+ apiece.
JK-NY
04-26-2003 04:54:06
 Re: Will sickle guards bend or break? in reply to James, 04-23-2003 15:18:48
Ive had beter luck straighteneing guards with a piece of pipe slipped over the guard like the others suggested. I imagine youd break less this way compared to a hammer but ive never broke too many either way.
JK-NY
04-26-2003 04:52:58
Roy in UK
04-25-2003 08:24:25
Well if you do break one, or have to take one off and replace it, don't throw the old one in the scrap bin... used in conjunction with a 3lb hammer they make a brilliant tool for drawing out fencing staples!
Bernie
04-24-2003 16:47:20
I have a Hesston mower with stub guards. I use my shop press to straighten them. One breaks once in a while. Also a narrow piece of thin metal either in front of or behind the mounting bolt will tilt it to make it line up. HTH
JMS/MN
04-23-2003 23:00:58
Just find a pipe about four feet long that slips over the guards, and bend them back into place. Much more control than wanging them with a BFH. Not likely to break, but if they do, what have you lost? Can't remember breaking one in the last 30 years of so.
Nathaniel Foss
04-23-2003 17:18:30
If the fingers do no move after being hit with a hammer (generly the yellow NH fingers(or guards)than heat them up cheery red with a torch and give them a few good wacks that is what we have always done with the littel ford
Tractor Dan
04-23-2003 17:10:30
i made a tool that slides over the guards and has a 3 foot handel so you can easy them right to were you need them like the other guys said once and a while youll get one that will break good luck
Tractor Dan
04-23-2003 17:09:54
Dick2
04-23-2003 16:40:49
Most sickle guards are made of relatively soft "maleable iron" that is designed to be bent, but sometimes they do have brittle spots where they will break. A lot of early farm implements had maleable iron parts that were used as a means of adjustment. The governor rods on MM tractors into the 50's were maleable iron; bending the rods was the only way to adjust the governor.
Dick2
04-23-2003 16:40:20
Hal/WA
04-23-2003 16:32:44
While I do not have any experience with your particular mower, I have adjusted many guards with a 3 pound hammer. Most got to where I wanted them to, and a few broke. Maybe I am wrong, but I thought that was the only way to adjust them. I have often had to adjust even new guards a little to get them to line up properly.
If the mower is new to you, I would sure try removing the offending guards to make sure they had been installed correctly and nothing was between the guard and the bar.
On my Ford 501, I have had problems with some farm store guards not fitting right on the bar. The ones from Ford/New Holland work better for me.
