JD #52 Plow
Bruce
04-23-2003 12:35:40
third party image
Can someone tell me about this hitch? Am I missing something, or did the old JD's have a hook-up for this? (OK - I'm not a JD guy - sorry). What is the best way to convert this for a normal pin hitch?
Leroy
04-27-2003 07:51:24
 Re: JD #52 Plow in reply to Bruce, 04-23-2003 12:35:40
Without that release you could roll the tractor over backward on you, be safe, use the release
Loren
04-26-2003 05:58:13
A standard horizontal loop clevis. Many have been for sale on this sight. You can also get them at most farm supply stores. The problem may be the device above the rear portion of the spring hitch. This need to slide forward freely to lock in the loop end of the hitch and the pin drop into the hole you see in the center of the picture.
Tractor Dan
04-23-2003 17:13:13
i have a number 52 that i pull with my 37 jd a that has original loop draw bar but when i pull with another tractor i just use a twisted clevis the hitch is made to release if you hook into something it does work pritty good
jhill
04-23-2003 13:22:31
The early A's and B's had a loop type hitch that worked with this style hitch. You just need a flat type clevis to adapt it to most tractors.
