JD 2R planter
jeff
04-22-2003 19:29:05
I bought a JD 2R planter and was wondering what model and year it might be. it is set up for a 3pt hitch, and is chain driven by a steel wheel on the back . Thanks for any help
Bayou Dave
04-24-2003 11:54:41
 Re: JD 2R planter in reply to jeff, 04-22-2003 19:29:05
third party image
Here is a picture of a 246/247. Missing the fertilizer hoppers, and with a home made row marker. Also has the rubber press wheel option. Owners manuals available from Deere for $12.00
jeff
04-24-2003 18:35:12
 Re: Re: JD 2R planter in reply to Bayou Dave, 04-24-2003 11:54:41
thanks for the help, that is the same as the one i bought
Bayou Dave
04-25-2003 05:27:36
 Re: Re: Re: JD 2R planter in reply to jeff, 04-24-2003 18:35:12
The model numbers 246/247 are located on the left side of each frame rail near the back. (looking at the planter from the front) You should be able to just make them out if they havent been painted over, or weathered off completely.
Hugh MacKay
04-23-2003 18:03:26
Jeff: Couple of questions. That primary drive chain from rear wheels, does it go up center between planting units as opposed to a chain on each unit? Does it have dry fertilizer hoppers? If so is it two hoppers serving each row or one hopper serving both? Is there an adjustable threaded 3/4" rod from top of 3 point mast to frame of planter? The planter I am most familiar with is the 246/247. Same planter except 247 has optional equipment for planting cotton. If you live in north, don't be put off by that cotton item. I live in Canada and mine is a 247 sold new here by a dealer. This may not be right simple either as John Deere used same basic design on a number of planters. Any details you can see would be helpful.
jeff
04-23-2003 18:43:32
 Re: Re: JD 2R planter in reply to Hugh MacKay, 04-23-2003 18:03:26
one chain drives both units, and there is a seperate fertilizer can for each row. thanks for the help
