NH 254 Tedder Rake
Kenneth S.
04-21-2003 13:49:55
Has anyone had experience with removing the cam track on the 254 tedder? Is there a trick? I have removed the wheel assembly, and all visible parts below the cam track, yet it still won't come off the shaft. I can move it up and down about 1/4", but beyond that there appears to be a ledge or other restriction on the lower shaft were the manual says it should slide off easily. The NH dealer says it might need to be pressed off or even torched off! That seems a little bit drastic to me- seems like torching would create 10 times the problem that I am trying to solve. Is there another hidden holding device, or a bearing inside the cam track that is very tight? Any help or advice would be appreciated.
Thanks, Kenneth
