Trip bucket springs
Gene
04-17-2003 07:08:46
I picked up an old loader in need of repair. The trip springs for the bucket are shot. I need new springs and have a question. How much resilience should the springs have? I assumed that the bucket would catch after you laid it on the ground, right? Or should the springs be heavy enough to pull the bucket back (while it is off the ground) until it locks? I looked at MCmaster-Carr and could not find springs long enough. I need a pair of 19''springs avout 1 1/8" to 1 1/4" wide. Any type of springs I should be looking at? (material wise). Does anyone have a source? Thanks in advance for all your responses. Gene
thurlow
04-17-2003 19:48:01
 Re: Trip bucket springs in reply to Gene, 04-17-2003 07:08:46
Our first loader had trip-type bucket; been a while, but my recollection is that with the bucket unlatched and the loader in the air, the bucket would hang about half-open. Should definitely latch with it on the ground. Can also latch it by picking the loader up and suddenly reverse the control lever; giving the loader a little "pop". As to the springs, if you're on good terms with the parts guys at your local dealer, I'm sure they can help with some "will fit" springs from another piece of equipment.
jim
04-17-2003 18:15:40
Gene - I use garage door opener springs to replace the original on my old Freeman loader. Works fine for me and one of the door springs will give you at least 2 replacements!
