Massey Ferguson loader
Rick
04-10-2003 05:33:15
I am looking for an OEM replacement 4-way control valve for a Massey Ferguson loader.
The model no. is 101F and serial no. is 30173. New or used, I do not care. Or, is there an aftermarket valve that will work in its place that requires little or no modifications to the method in which it mounts to the loader. Thanks for any reply back. Rick G.
Don H
04-10-2003 21:51:30
 Re: Massey Ferguson loader in reply to Rick, 04-10-2003 05:33:15
I have a parts manual for 101 loaders. I could look up part # but I would bet they are no longer available. Let me know how you solve this as I may be in the same boat some day. Mine is well worn but still in use.
Thanks Don
Rick
04-11-2003 13:46:18
 Re: Re: Massey Ferguson loader in reply to Don H, 04-10-2003 21:51:30
Don, thanks for the reply. I would certainly take you up on getting the part no. for the 4-way valve. Or even a number for a rebuild kit if there is one. If I do not find the original parts, I plan to use a drawing that Big Dean sent me which shows how to make a bracket and outfit it with an aftermarket valve. It will certainly work, it just will require a lot more work. You can send it directly to me or through this forum. Thanks for your help. RG
