WOODS BRUSH HOG??
CJ
05-23-1999 20:36:10
My Woods Brush Hog says I have to greese it once in a while(tag on top). Does anyone know where the fittings are that I should be greesing? Thanks
Dennis H.
05-23-1999 20:57:03
 Re: WOODS BRUSH HOG?? in reply to CJ, 05-23-1999 20:36:10
The pivot arm for the dolly wheel, the spindle on the dolly wheel, the u-joints on the shaft. Some had grease ports on the PTO sheilding. The gear box uses gear oil. Also, I would suggest using "anti-seize" on all the bolts under the cutting deck. The acid in the grass will often fuse the metals after prolonged use and make it near impossible to remove the blades without a "smoke wrench".
