Kewanee 13' disc
Steve Mason
04-02-2003 13:03:23
I am in need of a disc for my acreage. I found an old Kewanee 13' disc. I have a Farmall C (has the Super C engine) and I think it is rated somewhere around 25HP. Do you think I can pull this disk OK?
The ground I am working is mostly black dirt with a little clay here and there.
Any thoughts?
Thanks
Mark
05-14-2004 06:42:29
 Re: Kewanee 13' disc in reply to Steve Mason, 04-02-2003 13:03:23
A 13 Ft disc is a big disc. We run a turf grass farm and plow on a reguler basis, however my 10 ft JD 4 way in black land takes about 135 HP to pull. Power source (JD 4420). I talk to you today to converse about a plow I have that is in need of parts. Kewanne No.820. This is a 13 Ft disc 4 way. Each axle has 9 disc and takes an IH with 145 HP, dual rear wheels to pull. If your plow is to big and does not work out let me know I would like to see if these are the same plow. If so I maybe intrested in buying it.
I also would like to find out where you found it, that could be very helpful in finding parts in the future. Nice talking with you and have a great weekend.
JMS/MN
04-03-2003 07:35:41
Is that a single disc or a tandem disc? Tandem would have front and rear gangs, in an x pattern. No way the C would handle that. If it's a single row of discs, 13 feet wide, I think it would be quite a load as well. Years ago we pulled a 15' AC single disc with a WC, which is bigger than a C
Steve Mason
04-03-2003 07:52:59
 Re: Re: Kewanee 13' disc in reply to JMS/MN, 04-03-2003 07:35:41
sounds like ths is way more disc than my C can handle. The disc looks to be in good shape, owner says all bearings are good and he is asking $100 for it. If anybody is interested in it let me know and I'll hook you up with the owner. It is located in NW Iowa. Thanks for all the help guys!
James
04-02-2003 17:50:49
You might be able to pull it with the wheels fully down.
Hugh MacKay
04-02-2003 16:31:09
16" disc blades will require 1.25 to 1.5 hp per blade. If it doesn't, disc is in need of repair. Disc blades are sometimes spaced different. It is the number of blades that count. I had a 28 blade disc with 16" blades. Under right conditions it could bring Farmall 300 to 2nd gear. I liked to disc in 3rd. Later on I had a 44 blade disc with 18" blades, it loaded 656.
