Tractor chains
lyle
03-28-2003 05:46:09
I have 18.4x34 tires and I have a chance to buy 18.4x38 chains Is there a cheap way to make them fit on my tire size
Leroy
03-30-2003 08:02:20
 Re: tractor chains in reply to lyle, 03-28-2003 05:46:09
Just mount and hook in link needed and let either over lap and tie fast excess or cut off excess with a bolt nipper, nothing to have to weld back on
ole
03-29-2003 15:39:55
you may be able take up the extra with short rubber bungee cords. I have tried to purchase so called chain tighteners which are nothing more than a big rubber ring with four hooks attached. In the meantime, my short bungees do the same thing and I don't care if they have two or three a side. they are cheap enough and last a couple years until they wear out. I also make sure to hook them from behind the link to put the point of the hook out so as not to press it into the tire. good luck
KEG
03-28-2003 06:21:52
Go to tirechains.com for parts, if you need.
KEG
KEG
03-28-2003 06:21:10
KEG
Chet
03-28-2003 06:10:14
Fit them around the tire and determine how many links too long it is then torch off the excess links and weld the ends back on or use a quicklink.
