Load tires or not ?
Dave
03-26-2003 12:07:07
I have to dismount the rear tires on my JD AR. These tires are loaded now and the question is,
I plan to use this tractor for plow days this spring and pull a #44H two 14" plows. I have wheel weight. Can I get away with not loading the tires and still get good plow traction.
Leroy
03-30-2003 09:23:26
 Re: Load tires or not ? in reply to Dave, 03-26-2003 12:07:07
An AR will not use a mounted plow, with 2-14" on average stalk ground should pull unloaded but not on sod, had AR with 3-12" massey plows tires loaded with set of Deere factory weights needed all on sod plowing about 7" deep, with your 2-14" I would guess you will plow 7" to 8" deep, load will be about the same, rule of thumb, depth dezinged for, depth 1/2 of width or 12"-6"; 14"-7"; 16"-8"; If you take care of your tires there is no problem with calcium cloried in your tires, If you are going to be useing it for other than play then load the tires as you will also need that weight for traction on a disc harrow, 9' size good for that tractor
Wes
03-29-2003 16:40:03
I pulled a Massey Harris 3-14 with my JD A last year with unloaded tires. You should have no problem.
Dave, Sherburne, NY
03-29-2003 11:17:52
Everyday working tractor , load them. Show tractor no liquid save your rims.
Dave, Sherburne, NY
03-29-2003 11:16:58
Larry
03-28-2003 07:02:44
Loading tires? I only keep my tires loaded on my biggest tractor, which I use for plowing. Ford 5000. I use 2-14's on a 3 point, because it is really hard ground. I had to put 5 70 lb. weights on the front even, because it tends to ride light up there. Not a problem though, I sometimes have to steer with the brakes a little bit.
Larry
Larry
03-28-2003 07:02:19
Larry
Larry
03-28-2003 07:01:42
Larry
jal-SD
03-27-2003 11:32:45
DUMP THAT CRAP & SAVE YOUR RIMS! Be sure to wash them really well & get rid of ALL RUST & repaint before mounting tires. If you need more weight (which you shouldn't, w/only 2-14's) add more cast iron or concrete. (Thats what they make wheel weights for.) I hope the guy that thought of putting calcium chloride in tires is roasting somewhere. IMHO, it's the biggest headache there is for those of us who wish to preserve old tiron. (My $0.02 worth. jal-SD)
JMS/MN
03-26-2003 21:51:02
An AR with 2-14 behind it? Better tell the others to move over, or at least get out of the way!
paul
03-26-2003 18:21:16
If it's mounted you could get by without.
I'll assume it's a pull-type, then I'd prefer keeping the weight.....
--->Paul
JD
03-26-2003 16:26:07
I would keep them loaded.
