JD60 HYDRAULICS
Jeff S
03-22-2003 19:11:09
i have a trip bucket loader on my JD60 and a 3pt. mounted back blade. how can i set up the hydraulics so that the loader runs off of a seperate valve than the 3pt. eliminating the need to keep adjusting the metering valve. Right now the loader is hooked up to the auxillery hook up on the 3pt. Thanks for the help
Chris
03-23-2003 12:31:09
 Re: JD60 HYDRAULICS in reply to Jeff S, 03-22-2003 19:11:09
You are now faced with a problem so many early number series tractors owners like me are. Now here is what i am gonna do this week to eliminate your problem on my 60 im about to add a 45loader to. I am gonna go to my local hyd shop. By me a "T" to go into the high pressure line coming off the hyd pump. That T is a compression type fitting so it will require no brazing. Then im gonna add a 2 spool valve on my seat and then a return from that valve to the bottom hyd port on the powrtrol. sound easy enough. Go over to the john deere board and post your question to a man named clooney put his name in the subject. He will explain it better than i did but i gave you a crash course. Thanks Chris
