Okla/Kans Bill
03-13-2003 18:42:53
It occured to me after reading some of the posts in here that sombody might find it benificial to get some advice on planting corn, so, form the experienc of 34 yrs ill say this much. #1 NEVER BACK UP WITH THE PLANTER TRIPPED AND IN THE GROUND> In some instances, as with some JD, and IHC and probaby others, dont b ack up period, azs youll npot only plug your drop pipes with fresh dirt, youll break off the rear press wheels. So the bst advice is, if your planter has more than 2 wheels on the ground, and its old, dont back perod. If you do back up, and if you do get fresh dirt in the drop pipe, youll find out it actually go up some inches inside the pipe and is hades to clear out. If you dont find out you plgged up your pipes, youll go merrily down the rows planting nothing, and grinding up your seed corn under the planter box, or maybe just planting every other row. If you are a newbie, then strive for straight rows, not wavy , contoured ones unless you have to. Cultivating straight rows is bad enough on a newbie, but to have to follow snakes with broken backs up and down the row is alful. nNot to mention how much corn you will bre taking out while doing so. Try to keep your rear tractor tire track from the preceeding trip straight and easy to follow when you make ther return trip. I plant with a 1934 CC Case. If I place my rear tire in the previous tire track, then Im planting in 30in rows. If I half lap the track on the inside betwee tthe track and the planted row, that is still ok, but if I put the rtear tire altogether on the inside of my previous track then ill lose corn when Im cultivating because the schovels will rip it out. Likewisde,, if I get my tire on the outside of the previous tire track, then im losing ground, and if I go out a whole width of the tire, then my cultivators will not be able to get that stretch of weeds and grass and it will grow all season. Always remember to keep checking your sertilzer and or panter boxes to make sure youve got seed and fertilizer in them and are not just planting air in your furrows as youll nevcer know where you ran ut of seed at least till it comes up. MAKE SURE YOUVE GOT THE RIGHT PLANTER PLATES FOR THE TYPE OF SED YOUR PLANTING> Plats come in small, medium rounds, medium flats, and large. So does the seed. Match them
