JD no. 5 Sickle Mower
jailkeeper
03-12-2003 22:01:37
Can anyone tell me where to get parts for a JD no.5 sickle mower? I pulled one out of a fencerow last year expecting it to be junk but it seems to be in fairly decent shape. Unfortunately, I broke the cast iron piece that holds the bar on the frame.
Also, can I re-do the attachment points to fit a 3 pt. hitch on my Farmall H? I know, red and green don't mix but I hate to just junk it!
Rick
03-14-2003 00:58:23
 Re: JD no. 5 Sickle Mower in reply to jailkeeper, 03-12-2003 22:01:37
I have a no8 if that would help.Rick
jailkeeper
03-13-2003 17:13:46
Thanks to everyone for the replies, and the e-mails. I was literally flooded with e-mails. Thanks again guys, and especially to those that make YT a great website!
Steve
bob
03-13-2003 13:21:00
that part can be braxed or welded most of them around here have been the one i HAVE NOW ISN,T but they are know to get cracked etc It won,t be a problem and mower is well worth fixing
ron in MN
03-13-2003 08:44:18
Many parts for these mowers are still available from John Deere. That is things like the pitman and cutter bar parts.
Bob G
03-13-2003 08:14:53
Here's a link to hooking the #5 to a tractor. There are several ways to do it.
http://www.retiredtractors.com/No5/Nohitch.html
JD70Jim
03-13-2003 07:50:33
You are aware that you can hook up a #5 to an H Farmall perfectly well without any 3 point at all, arn't you?
If therenis any side to side sway in your 3 point hitch set up, it will have to be secured. The #5 was meant to be ridgidly hitched to the tractor. On a John Deere, at least, there were round bars which bolted to the drawbar frame. The clamps on the mower attached to them. A different setup was used with the Farmalls and is best illustrated in the OWNERS MANUAL at the back of that book! Using the #5 with a 3 point hitch wasn't reccomended, or specifically the 3ph on a 420JD wasn't reccomended. That is because it had side to side movement. The 3ph on the 420 is just like most a/m hitches I have seen for most older tractors.
My Father successfully used a #5 with a 420 some 30 years ago because my he had fabricated a special, homemade hitch which provided the round bar to clamp onto, and which solidly braced the 3ph from any movement side to side.
David from Kansas
03-13-2003 07:04:52
I used a #5 JD mower on my Farmall M for years. Worked great. I still use it occasionally on my 4020. My M didn't have 3 point so I just bolted the drawbar of the mower to the drawbar support of the tractor after removing the drawbar of the tractor from it's support and tying it off to the side out of the way. I have quite a few parts for a #5 but not the casting you are talking about. If you need anything else let me know. David
david e stephenson
03-14-2003 07:23:26
 Re: Re: JD no. 5 Sickle Mower in reply to David from Kansas, 03-13-2003 07:04:52
on my uncles farm in s.e.ia we used the no 5 j.d.mower on a f20,h,m \and a john deere before he bought a disc mower conditioner they were great old mowing machine. place a ad in the farm section of the paper or call a used tractor dealer. their are still several of these mower around in s.e.iowa we just bolted the mower on the drawbar and went to mowing.
david e stephenson
03-14-2003 07:21:58
Delbert
03-13-2003 05:40:43
Check salvage yards fence rows etc you might find another mower. Also could it be welded? I have your combo works great. If you have jd hitch you can put a pipe in the hitch and weld pins in each end for 3pt. Also helps to have double spool to run 3pt and cylinder on mower. Where I live there are quit a few of these. If this mower has the hitch for ih tractors take the hitch off 3 pt will fit right up to it. Well enough confusion. Good luck.
Delbert
03-13-2003 05:40:10
Chris
03-13-2003 04:17:33
put a wanted ad on this site. There are lots of people out there that have the mowers junked. That is a great mower. Get you a manual to it off ebay. Its a good combo for your H. Thanks Chris
