Sickle bar mower questions
MikeH
10-16-1998 14:49:31
I could use some help from the pros. I bought a Farmall F12 to restore and make noise with. With it came a sickle bar mower, two plows, blades and cultivators. I would like to see if the mower and cultivators work. The mower has a 7ft blade and is marked with an id of M2471. Is there any info available regarding mounting this stuff and operating with it? I need to replace a pitman arm, but other than that, it looks complete (what do I know?). Doesn't mean it will mow, but I would like to try. Any advice for a weekend warrior on 15 acres?
Milan Radakovic
10-18-1998 15:57:26
 Re: sickle bar mower questions in reply to MikeH, 10-16-1998 14:49:31
: I could use some help from the pros. I bought a Farmall F12 to restore and make noise with. With it came a sickle bar mower, two plows, blades and cultivators. I would like to see if the mower and cultivators work. The mower has a 7ft blade and is marked with an id of M2471. Is there any info available regarding mounting this stuff and operating with it? I need to replace a pitman arm, but other than that, it looks complete (what do I know?). Doesn't mean it will mow, but I would like to try. Any advice for a weekend warrior on 15 acres?
You may be able to get a manual for that from your Case/IH Dealer. Or try a swap meet.
