Sickle Mower Sections Which Ones To Use.
Chris
02-24-2003 17:26:19
Ok I have a #5 JD sickle mower. I am cutting mostly grass hay with some clover kinda heavy in spots. Now what is the best sections. Top or bottom serrated. I have a blade im gonna probably redo but i need to know which sections are best. Thanks Chris
RayP(MI)
02-25-2003 09:52:55
 Re: Sickle Mower Sections Which Ones To Use. in reply to Chris, 02-24-2003 17:26:19
Be aware that all sections are not made to the same size specifications. Take along one from your present blade when you go to buy. Neighbor gave me a whole box of sections that I couldn't use on my JD mower. Oh, well.
RayP(MI)
02-25-2003 09:47:53
Delbert
02-25-2003 05:25:36
Good ledger plates in gaurds will help in tough grass. The old # 5 will mow with any mower.
Steve from New Holland
02-24-2003 19:37:51
Well, I suppose there are many opinions, so I'll give you mine. Any blade will cut well when it is new and sharp. The real question is: Which one will still cut once the blades become a little dull. In my opinion, that would be the top serrated. The bottom serrated was popular for many years because they could be sharpened. However, they do not do well unless you really keep after the cutting edge. I just really like the top ones to keep cutting fairly well even when slightly dull. Just my opinion, Steve
02-24-2003 19:37:12
paul
02-24-2003 18:23:08
Here where I live in MN, there are three options: Smooth, bottom & top.
Smooth works well in finer or shorter grass hays. Might be a little slower at times, but doesn't clog up so bad.
Top works well in taller stemmy stuff. It has the possibility of clogging up with short fibers from fine grass hays.
Bottom is a pretty good compromise. Works well if you get into all types of grass/ clover/ alfalfa. In addition, you can sharpen the blades without losing the serration right away.
Anyhow, this is local best advise - might be different in other locations.
--->Paul
jim
02-25-2003 05:59:45
 Re: Re: Sickle Mower Sections Which Ones To Use. in reply to paul, 02-24-2003 18:23:08
Whichever you decide to go with,remember to change the guards also because they're probably badly worn also. Remember to bolt the new sections on rather than rivet (much easier to replace broken sections).With both new sections and guards,you'll swear you've got a new mower!
