What size/type of bushog for an 8N
Kevin
08-04-1998 09:29:58
I have a '48 8N, and have about 4 acres that needs to be cut a couple of times a summer. What is the proper size and type of mower for my tractor? And what should a good used one cost me?
Steven
09-10-1998 18:01:58
 Re: What size/type of bushog for an 8N in reply to Kevin, 08-04-1998 09:29:58
I have a '51 8n and I use a 5 foot mower. They will usually cost between $500 - $600.
brian
08-04-1998 12:30:05
: I have a '48 8N, and have about 4 acres that needs to be cut a couple of times a summer. What is the proper size and type of mower for my tractor? And what should a good used one cost me?
My father in law has a 4ft and my uncle uses a 6 ft brushhog, both on 8n's The 8n will lift either with no problems at all, if your lift is working properly. So its up to you. For 4 acres, I'd guess either would do.
I don't know anything about prices used.
Brandon
08-04-1998 13:05:45
 Re: Re: What size/type of bushog for an 8N in reply to brian, 08-04-1998 12:30:05
: : : I have a '48 8N, and have about 4 acres that needs to be cut a couple of times a summer. What is the proper size and type of mower for my tractor? And what should a good used one cost me?
: I would use a 5 ft bushhog with an 8n. Expect to pay about 300 dollars. Do not foget the override clutch.
Indian Guy
08-05-1998 11:35:10
 Re: Re: Re: What size/type of bushog for an 8N in reply to Brandon, 08-04-1998 13:05:45
: : : : : I have a '48 8N, and have about 4 acres that needs to be cut a couple of times a summer. What is the proper size and type of mower for my tractor? And what should a good used one cost me?
: : I would use a 5 ft bushhog with an 8n. Expect to pay about 300 dollars. Do not foget the override clutch.
My pa in law uses a five footer and has had it try to run him into trees and stuff. Where might one find this override clutch? Thanks Me
Stan Disbrow
08-07-1998 10:22:08
 Re: Re: Re: Re: What size/type of bushog for an 8N in reply to Indian Guy, 08-05-1998 11:35:10
: : : : : : : I have a '48 8N, and have about 4 acres that needs to be cut a couple of times a summer. What is the proper size and type of mower for my tractor? And what should a good used one cost me?
: : : I would use a 5 ft bushhog with an 8n. Expect to pay about 300 dollars. Do not foget the override clutch.
: My pa in law uses a five footer and has had it try to run him into trees and stuff. Where might one find this override clutch? Thanks Me
Any tractor/ag supply store would have them. One the net, try Agri-Supply www.agri-supply.com They cost about $40 and ratchet when the Hog tries to push the machine. They fit on the PTO shaft and extend it a few inches, so you might have to shorten the PTO drive shaft.....
stoney
08-07-1998 12:12:33
 Re: Re: Re: Re: Re: What size/type of bushog for an 8N in reply to Stan Disbrow, 08-07-1998 10:22:08
You can buy an overrunning clutch from the sponsors of this site or from new Holland. ABout $10 difference in price. I just bought a NH one for $65 - no cutting of shaft was required for me - make sure you know the size of your PTO shaft - 1 1/8 or 1 3/8.
