Will snow chains work in mud?
Muddy
02-20-2003 17:58:44
Trying to disc what we call drilling mud. They use it on the drilling rigs and when they are through they spread it on pasture and disc it in for fertilizer. The mud is relly slick and it is hard to get traction a four wheel drive tractor will work but I was wondering about using snow chains on the back of a 2 wheel drive tractor with duals and weight it down with water and weights will the chains help? The tires get the mud in the lugs just like any kind of mud and then that just makes it worse. I know that we shouldn't be plowing when it is wet but we have to get this mud mixed into the soil as soon as we can. Thanks
Skinner
02-22-2003 05:25:45
 Re: Will snow chains work in mud? in reply to Muddy, 02-20-2003 17:58:44
What part of the country are you in? I assume your using spud mud and not drilling mud or oil base? Oil base shaker shavings makes great driveways and pads, however it's pretty much outlawed now since you have to keep a manifest, which means that it has to be properly disposed of. Last load of shavings we got was about 3 years ago, and now, it's almost impossible to get a truck to pump into your pond bottom. I would think spud mud would be rich in a lot of minerals and would work great, much deeper than that, I honestly don't know what the results would be.
Dick Kline
02-21-2003 09:07:35
Find yourself a place that sells log skidders. They will have some real chains. They look like X's between the side chains and are made from rings 1" to 2" in diameter. Use them years ago and they get the job done when chains is the only answer..... .
Greg Miller
02-21-2003 06:18:36
yes. use the chains. there are different types also. one common type is a simple link chain. another is a twisted link chain and the third most common type is the v-bar. these v-bar chains give the best traction since there is a v-shaped piece welded to the cross link in the chain.
Hugh MacKay
02-21-2003 03:06:02
I really never heard them refered to as snow chains. To me they were always tire chains, and yes they will increase traction on just about any surface. Over the years there have been adaptions made to increase the effectiveness of chains on hard ice. Example of these are the Canadian ring chain and ice chains. Both of these add devices somewhere between corks on track shoes and horse shoes
JD
02-20-2003 18:20:04
Yes they will help. I used tire chains for plowing when we had a vary wet fall.
