JD Model 44H Set-Up Questions
Mike
02-20-2003 10:21:32
Now that I have a manual for the plow I am wondering. The book says to move rear wheels in to narrowes point, then adjust plow to run in the furrow not to adjust with swinging draw bar. So far I have been adjusting at the draw bar to get the plow to track properly. Is this a big deal to do it by the book? I intend to restore the plows and keep them. They are in real nice shape other than a sand blast job and painting. Thanks, Mike
Butch(OH)
02-21-2003 04:37:54
 Re: JD Model 44H Set-Up Questions in reply to Mike, 02-20-2003 10:21:32
Although moving the drawbar from center will place the plow in the correct position behind the tractor having it anywhere but centered causes the tractor to wander around with the varying loads and you have to do a lot more steering than needed. Assuming that your plow is a two bottom you'll want your rear wheels clear in. Place the tractor drawbar in the center and adjust the plow position by moving the plow drawbar and brace. You want the plow drawbar to be pulling as straight as possible by moving it sideways on the hitch plate. Small adjustments are made with the brace. I know what you mean about the book instructions, makes the job appear to be a lot more than it is.
ron in MN
02-20-2003 15:47:57
According to what I have in my operator's manual for a Model 50 tractor, it says to leave the tractor drawbar in the exact center and do all offset adjusting on the plow hitch keeping the plow hitch parallel to the furrow wall. The reason given is that "this provides the maximum protection from the safety release or cushion hitch on the plow when hitting an obstruction".
Also the offsets (when using a Model 50 tractor) are only needed with a 2-12, 2-14, 2-16 or 3-12 plow. This example is given for general purpose tractors with regular axles and 10-38 rear tires.
ron in MN
02-20-2003 15:47:41
ron in MN
02-20-2003 15:47:34
