JD HH spreader
Dustin
02-19-2003 18:11:59
Came by an old hh spreader, sn 1986, complete but needs new sheet metal, what can you tell me bout this thing and any advice as to weather to bother trying to pick it up or not, it's on rubber with tractor hitch if that means anything, thanks in advance
John
02-20-2003 05:33:30
 Re: JD HH spreader in reply to Dustin, 02-19-2003 18:11:59
Hi, these are good spreaders. I have a H model that I bought for $500 in good working order. If it needs alot of work then I think $100 would be a good price.
F14
02-19-2003 18:15:21
The HH (Horse H) spreader is a 4 wheel version of the JD H spreader. Parts are still available from JD. I bought one a couple of years ago and put a new bottom in it, got axle bearings and a couple of ratchet/pawl springs from JD. They also have the parts book for it.
Dustin
02-19-2003 20:31:25
 Re: Re: JD HH spreader in reply to F14, 02-19-2003 18:15:21
that's great, I plan on locating the owner soon, what is a reasonable offer, like i say, the sides and bottom are shot but the tires wheels and all the chains/beaters are complete. thaks alot
F14
02-20-2003 03:47:38
 Re: Re: Re: JD HH spreader in reply to Dustin, 02-19-2003 20:31:25
I paid $100 for mine, put about $300 plus labor into it. The axle bearings were frozen, the bottom needed to be replaced, the angle iron over the axlem mounts had to be cut out and replaced and the sides needed to be patched/reinforced around the beater bearings.
